You could copy the Space Type and Construction Set Wizard and replace the json in the resources folder. @macumber can better speak to use of the json file in the installed version of OpenStudio, but there is a user script in the plug-in that works just like the wizard, you can replace it with yours. The second use is to pre-populate many measure tag choice lists in the GUI with space types, construction type, climate zone etc. I don't know if there is currently a way to easily use a custom json for this. @macumber can answer that.
