Calculation 37 in the ideal air loads engineering reference suggests that at least in EnergyPlus it's a fixed supply temperature, and the mass flow is the calculated value.
Calculate supply air mass flow rate required to meet zone sensible load at the applicable (heating or cooling) supply temperature limit (Tmax,heating or Tmin,cooling)
