Another case of asking a question and finding the answer right after.
Each surface (and subsurface) has a setVertices method which accepts a vector of Point3d.
Let's say you want to only change the third vertices of a triangle. s is a Surface or SubSurface
# First two points stay the same
a = s.vertices[0]
b = s.vertices[1]
# Create a new point at (x, y, z) = (0, 1, 2)
c_prime = OpenStudio::Point3d.new(0, 1, 2)
# Do the change
s.setVertices([a, b, c_prime])
