EnergyPlus and OpenStudio now share a single login, you will only need OpenStudio.net account. If you Click Here, it will take you to Login page and you will be able to Login with EnergyPlus. Is that what you have been doing without success?
EnergyPlus and OpenStudio now share a have been moved to single login, you sign-on solution. You will only need OpenStudio.net account. If you Click Here, it will take you to Login page and you will be able to Login with EnergyPlus. Is that what you have been doing without success?
