The solution I’ve come up with is to put my return pipes on the bypass branch of the demand side of the loop (before the mixer), instead of after the mixer. Seems to be working well; the flow through my return pipes no longer includes the makeup cold water.
The solution I’ve come up with is to put my return pipes on the water demand bypass branch of the demand side of the loop (before the mixer), instead of after the mixer. Seems to be working well; the flow through my return pipes no longer includes the makeup cold water.
