As you're running on linux, you had to add the parameter /disablerubyapp, needed to run SketchUp version 2014 & 2015, is also the reason why plugins don't work. Even dos2unix all the *.rb files didn't satisfy neither. Also installing under wine the new ruby versions 2.0 & 2.4 didn't solve. Got also an exit out of SU2015 by simple pas over the file-menu. As far as now best version to run on linux is the 2013. There you'll have the possibility to run ruby scripts. Having a problem with an error concerning shell32. dll
Greetings Xiao Shi Zi.
