In general, I know of no available tools that would take either of these input formats and compute DA, unfortunately. Again, you can use a spreadsheet to take the illuminance values (option two in your post) and plot them, or you could use OpenStudio to take an idf (option one above -- assuming it has all the daylighting objects properly placed) and run it through an annual simulation with Radiance, which will produce a summary csv file which does a lot of the work for you.
Many of the other tools out there (e.g., Honeybee, DIVA for Rhino, SPOT) that are geared toward climate-based daylight modeling have their own methods for reporting DA and other dynamic daylight metrics, as well. In most of these cases you will need to build a new model in the host program(s) before running the analysis and getting your desired results.
Many of the other tools out there (e.g., Honeybee, DIVA for Rhino, SPOT) that are geared toward climate-based daylight modeling have their own methods for reporting DA and other dynamic daylight metrics, as well. In most of these cases sases you will need to build a new model in the host program(s) before running the analysis and getting your desired results.
