The post below lists many viable options for obtaining an AMY (Actual Meteorological Year) in EnergyPlus format (.EPW)
What are the available sources for historical weather data - link
If you are able to obtain the correct historical data, the post below may help you translate that data into an EPW file for use in EnergyPlus
How do you make an energy plus input file from real weather data - link
