Yes, it is possible. See https://bigladdersoftware.com/epx/docs/9-2/ems-application-guide/general.html#weather-data If you generate the edd file, you will find an actuator of the kind:
EnergyManagementSystem:Actuator Available,Environment,Weather Data,Wind Speed,[m/s]
Yes, it is possible. See https://bigladdersoftware.com/epx/docs/9-2/ems-application-guide/general.html#weather-data http://nrel.github.io/EnergyPlus/EMS_Application_Guide/EMS_Application_Guide/#weather-data If you generate the edd file, you will find an actuator of the kind:
