Looks like you've found an issue, which I've filed here. The grid view on the thermal zones tab has an incorrect SI to IP conversion.
Until this gets fixed, the IP number you see in the inspector on the HVAC Systems tab is the number that will be put into the IDF and used during the simulation. You can also switch to SI units and use either the grid view on the Thermal Zones tab or the inspector on the HVAC systems tab.
