Export the osm-file to idf from the OpenStudio menu to any working directory:
Then run the exported idf-file with EnergyPlus launcher. If the EPlus simulation crashes, this is probably a OpenStudio export failure and the osm-file should be sent to OpenStudio support. From my experience, in some cases OpenStudio does not produce required idf-objects as e.g. in this case, where I could identify what was missing.
