The report variable representing the latent cooling energy or rate describes system performance with regard to moisture energy transfer. There are multiple reports for the ideal loads air system. The cooling components of latent heat transfer are shown below.
Zone Ideal Loads Supply Air Latent Cooling Rate [W]
Zone Ideal Loads Zone Latent Cooling Rate [W]
Zone Ideal Loads Outdoor Air Latent Cooling Rate [W]
The calculations for latent performance are similar for each of these reports. The total enthalpic energy transfer rate is calculated and then the sensible (temperature) component is subtracted from this value. This value is reported regardless of humidistat usage.
$$Q_{lat} = [ \dot{m} \times ( H_{supply} - H_{mixedair} ) ] - Q_{sens}$$
where:
$\dot{m}$ is the zone air mass flow rate,
$H_{supply}$ is the ideal loads air system output directed to the zone,
$H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and
$Q_{sens}=\dot{m}\times c_p \times (T_{zoneinlet}-T_{zone})$.
where:where,
where,
$\dot{m}$ is the zone air mass flow rate,rate,/s/s
zone,zone,
where,
$\dot{m}$ is the zone air mass flow rate,/s/s
rate,
$H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $Q_{sens}=\dot{m}\times c_p \times (T_{zoneinlet}-T_{zone})$.
where, $\dot{m}$ is the zone air mass flow rate,
rate, $H_{supply}$ is the ideal loads air system output directed to the zone,
zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $Q_{sens}=\dot{m}\times c_p \times (T_{zoneinlet}-T_{zone})$.
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $Q_{sens}=\dot{m}\times $$Q_{sens}=\dot{m}\times c_p \times (T_{zoneinlet}-T_{zone})$.(T_{zoneinlet}-T_{zone})$$.
$$Q_{lat} = [ \dot{m} \times * ( H_{supply} - H_{mixedair} ) ] - Q_{sens}$$
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $$Q_{sens}=\dot{m}\times c_p \times $$Q_{sens}=\dot{m}c_p(T_{zoneinlet}-T_{zone})$$.
$$Q_{lat} = [ \dot{m} * ( H_{supply} - H_{mixedair} ) ] - Q_{sens}$$
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $$Q_{sens}=\dot{m}c_p(T_{zoneinlet}-T_{zone})$$.$$Q_{sens}=\dot{m}.c_p*(T_{zoneinlet}-T_{zone})$$.
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $$Q_{sens}=\dot{m}.c_p*(T_{zoneinlet}-T_{zone})$$.$$Q_{sens}=\dot{m}.c_p.(T_{zoneinlet}-T_{zone})$$.
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $$Q_{sens}=\dot{m}.c_p.(T_{zoneinlet}-T_{zone})$$.$$Q_{sens}=\dot{m}c_p(T_{zoneinlet}-T_{zone})$$.
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $$Q_{sens}=\dot{m}$Q_{sens}=\dot{m}c_p(T_{zoneinlet}-T_{zone})$$.(T_{zoneinlet}-T_{zone})$.
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $Q_{sens}=\dot{m}c_p(T_{zoneinlet}-T_{zone})$.
$$Q_{lat}
Qlat = [ where, $\dot{m}$ is the
Qlat = [ Mdot * ( Hsupply - Hmixedair ) ] - Qsens
Qsen
where:
Mdot = zone air mass flow rate
Hsupply = ideal loads air system output directed to thezone
Hmixedair = air enthalpy entering the ideal loads air system (including outdoor air)
Qsens = Mdot * Cp * (Tzoneinlet - Tzone)
where:
Qlat Q_Lat = [ Mdot * ( Hsupply - Hmixedair ) ] - Qsen
