I bet your Job object is not actually being created properly, resulting in it being None or an Optional. This would then cause the error when you go to enqueue that Job.
Looking at the header file for createModelToIdfJob(), it wants an openstudio::path as an input. I bet if you wrapped your paths in openstudio.path()
then it should work as you expect.
j = openstudio.runmanager.Job(
openstudio.runmanager.JobFactory.createModelToIdfJob(
openstudio.path(os.path.join(osm_path, osm_name)),
openstudio.path(output_path)
UPDATE:
Make sure that rm_path is a path to a database file.
rm = openstudio.runmanager.RunManager('/Users/local_user/Desktop/test_run.db', True, True, False, False)
If the database file does not exist, RunManager will create one for you. I was able to reproduce your error locally on my Mac when I just used...
rm = openstudio.runmanager.RunManager('/Users/local_user/Desktop/', True, True, False, False)
When the path points to a database file, it works.
I will say that using RunManager to translate from Model to IDF is kind of overkill. You can do the same, better and faster, just using ForwardTranslator.
# Forward Translate from OSM to IDF and save()
translator = openstudio.energyplus.ForwardTranslator()
idf_string = translator.translateModel(test_model)
with open('/Users/local_user/Desktop/test_idf.idf', 'w') as idf_file:
idf_file.write(idf_string)
Then you can run that IDF file using RunManager to createEnergyPlusJob...
ep_tool = openstudio.runmanager.ToolInfo('/Applications/EnergyPlus-8-3-0/energyplus') # ep path
job = openstudio.runmanager.JobFactory.createEnergyPlusJob(
ep_tool,
'/Applications/EnergyPlus-8-3-0/Energy+.idd', # idd path
'/Users/local_user/Desktop/test_idf.idf', # idf path
'/Applications/EnergyPlus-8-3-0/WeatherFiles/Chicago.epw', # epw path
'/Users/local_user/Desktop' # output path
rm.enqueue(job, True)
UPDATE:
rm = openstudio.runmanager.RunManager('/Users/local_user/Desktop/test_run.db', openstudiorunmanager.RunManager('/Users/local_user/Desktop/test_run.db', True, True, False, False)
rm = openstudio.runmanager.RunManager('/Users/local_user/Desktop/', openstudiorunmanager.RunManager('/Users/local_user/Desktop/', True, True, False, False)
ep_tool = openstudio.runmanager.ToolInfo('/Applications/EnergyPlus-8-3-0/energyplus') openstudiorunmanager.ToolInfo('/Applications/EnergyPlus-8-3-0/energyplus') # ep path
openstudiorunmanager.JobFactory.createEnergyPlusJob(
ep_tool,
UPDATE:
Make sure Next if that rm_path is a path to a database file. does not work then try this...
openstudio.Application.instance().application(True)
rm = openstudiorunmanager.RunManager('/Users/local_user/Desktop/test_run.db', openstudio.runmanager.RunManager(rm_path, True, True, False, False)
If the database file does not exist, RunManager will create one for you. I was able to reproduce your the error locally on my Mac when I just used...
rm = openstudiorunmanager.RunManager('/Users/local_user/Desktop/', True, True, False, False)
I and adding openstudio.Application.instance().application(True)
solved the runtime error for me.
If THAT doesn't work the follow will say that using RunManager to translate create an EnergyPlus job. You will need to Forward Translate from Model to IDF is kind of overkill. You can do the same, better and faster, just using ForwardTranslator.first...
idf_string.save(openstudio.path('/Users/local_user/Desktop/test_idf.idf'), True)
rm = openstudiorunmanager.RunManager('/Users/local_user/Desktop/test_run.db', openstudiorunmanager.RunManager('/Users/local_user/Desktop/sizing_run.db', True, True, False, False)
ep_tool = openstudiorunmanager.ToolInfo('/Applications/EnergyPlus-8-3-0/energyplus') # ep path
job = openstudiorunmanager.JobFactory.createEnergyPlusJob(
ep_tool,
While this is a lot more code, it should be similar to your intent with createModelToIdfJob
and then running that file.
If you ONLY want to go from OSM to IDF then the first three lines of code are by far the best and easiest method by using ForwardTranslator.
UPDATE:
Next if that does not work then try this...
rm = openstudio.runmanager.RunManager(rm_path, True, True, False, False)
I was able to reproduce the error on my Mac and adding openstudio.Application.instance().application(True)
If THAT doesn't work the follow will create an EnergyPlus job. You will need to Forward Translate from Model to IDF first...
rm = openstudiorunmanager.RunManager('/Users/local_user/Desktop/sizing_run.db', True, True, False, False)
ep_tool,
