I have encountered Temperature out of bounds messages in many cases in my models, especially with heat-pumps. The ways to eliminate such problems are manyfold. Successfull approaches have been:
- run the model with extensive output on various variables (even down to System node temperatures etc.) that can help to understand how the model behaves, and may explain where the excessive temperatures come from; I usually use ResultsViewer to diagnose the origin of the problem
- Check: does your model converge at all ? - Then the output is not reliable
- Are you able to eliminate all other warnings in the err-file, or at least to justify ignoring them; (have you chosen the all/extra warnings for output ?)
- non-convergence can be due e.g. to badly chosen setpoints or setpoint managers, bad sizing assumptions
- You could also selectively switch off/on heating or cooling components in order to analyze under which conditions your model converges and does not run into temperatures out of bounds.
- controlling the behaviour of the system can be improved by replacing conventional schedules by EMS-driven schedules: By implementing a logic for deploying heating/cooling components I have also been able to eliminate Temperature-out-of-bounds messages.
(even down to System node temperatures etc.)that can help to understand how the model behaves, and may explain where the excessive temperatures come from; I usually use ResultsViewer to diagnose the origin of the problem - Check: does your model converge at all ? - Then the output is not reliable
