@macumber added code to the OpenStudio SketchUp plugin that watches to see if the OSM file was saved by something other than the SketchUp plugin. This was done to alert the user to re-load the file if they opened and altered it (and saved it) using the stand alone OpenStudio application and then came back to the plugin. This is in PluginPathWatcher.rb
Maybe you can use code similar to this within your thermal bridge tool to see if there is an updated OSM available.
