See the two-speed coil object (Coil:Cooling:DX:TwoSpeed) and the parent object CoilSystem:Cooling:DX.
The speeds entered in the coil object will be used to select the air flow rates and therefore the fan speed.
The example file 5ZoneAutoDXVAV shows how this coil type is used in the coil system.
