Ah, I see what the problem is - if we pull the model into OpenStudio we can see that a bunch of the external walls are facing the wrong way. The north and south walls are the same because they're both facing south. If you're using the sketchup plugin you could just reverse the surface normals to fix this. Alternatively iirc you'd need to reverse the order of the vertices for those walls.
