The openstudio_results measure you are using (with OSApp 1.7.0 / OS SDK 3.7.0) is outdated compared to a recent change in EnergyPlus that renamed the "District Heating" column in the SQLFile to "District Heating Water" (as it also added a "District Heating Steam" one).
This was already filed upstream, but I just commented on it as well: https://github.com/NREL/openstudio-common-measures-gem/issues/162#issuecomment-2388162967
That being said, the current issue appears to be only for cashflow, and the HVAC Load Profiles section works fine if you use OpenStudio SDK 3.8.0, meaning you should use the recently released OpenStudio Application 1.8.0 and the latest openstudio_results measure from the BCL.
Then you get the right profile:
The openstudio_results measure is outdated compared to a recent change in EnergyPlus that renamed the "District Heating" column in the SQLFile to "District Heating Water" (as it also added a "District Heating Steam" one).
That being said, the current issue appears to be only for cashflow, and the HVAC Load Profiles section works fine if you use OpenStudio SDK 3.8.0, meaning you should use the recently released OpenStudio Application 1.8.0 1.8.0 and the latest openstudio_results measure from the BCL.
