To expand on Julien’s comment, this is a known issue. There is a workaround in that link if you want to continue using OpenStudioApplication 1.7, otherwise you will need to use the newly released OpenStudioApplication 1.8.
To expand on Julien’s Julian’s comment, this is a known issue. There is a workaround in that link if you want to continue using OpenStudioApplication 1.7, otherwise you will need to use the newly released OpenStudioApplication 1.8..
