Error detected in Object=FENESTRATIONSURFACE:DETAILED, name=SUB SURFACE 7 * ~~~ * Field [Construction Name] is required but was blank *
Looks like you need to either assign constructions directly to the interior sub-surface objects or just make sure that you use a default construction set for the building that has a construction assigned for interior doors. The construction sets used in our templates should already do this.
