This is actually an Output:Meter (or Output:Meter:XXX). It'll function the same, but this isn't the same object.
Example:
Output:Meter,
NaturalGas:Facility, !- Key Name
Timestep; !- Reporting Frequency
Output:Meter:MeterFileOnly,NaturalGas:Facility,Timestep;
You can take a look at the eplusout.mdd to find available meters for your simulation, provided you have added this object
Output:VariableDictionary,
IDF, !- Key Field
Unsorted; !- Sort Option
For what it's worth, the same can be done in OpenStudio SDK (Ruby here):
include OpenStudio::Model
m = Model.new
o = OutputMeter.new(m)
o.setInstallLocationType("Facility".to_InstallLocationType)
o.setReportingFrequency("Timestep")
o.setFuelType("NaturalGas".to_FuelType)
o.setMeterFileOnly(false)
Example:
Output:Meter,
IDF, !- Key Field
m = Model.new
