@MJWitte and @JasonGlazer
Thanks for providing all the details and clarfication about the slab preprocessor. I was wondering if you could please help me with the following relevant question. I am trying to add the Site:GroundTemperature:FCfactorMethod object to my IDF. In order to get the 12 required monthly fields for that object, I ran the slab preprocessor program (using EP-Lunch Utilities and the example file that existed in the EnergyPlus directory: PreProcess\GrndTempCalc). Running that IDF, generates another file, that is called _slab.gtp. That file includes four monthly tempretaures, including Taverage, Tperimeter, Tcore, and Tinside. I guess the Taverage would be the correct choice to fill the Site:GroundTemperature:FCfactorMethod fields. Could you please confirm if this approach looks correct. If not, what would be the alternative solution to generate that object.
Thanks so much in advance.
object to my IDF. In order to get the 12 required monthly fields for that object, I ran the slab preprocessor program (using EP-Lunch Utilities and the example file that existed in the EnergyPlus directory: PreProcess\GrndTempCalc). Running that IDF, generates another file, that is called _slab.gtp. That file includes four monthly tempretaures, including Taverage, Tperimeter, Tcore, and Tinside. I guess the Taverage would be the correct choice to fill the Site:GroundTemperature:FCfactorMethod fields. fileds. Could you please confirm if this approach looks correct. If not, what would be the alternative solution to generate that object.
Thanks so much in advance.advance.
