There is a related thread. It is not about once this happens. A few tips to avoid issue.
- Don't use undo
- Don't explode spaces or make a SketchUp group or component combining multiple spaces.
- Don't save the SketchUp file unless you need to. Opening the OSM directly is more reliable.
- Use SaveAs frequently so you have many OSM files you can roll back to.
Here is a link with tips once you suspect a probelm in a model
- Don't use undo
- Don't
explodeexlode spaces or make aSketchUpSketchup group or component combining multiple spaces. - Don't save the SketchUp file unless you need to. Opening
theth OSM directly is more reliable. - Use SaveAs frequently so you have many OSM files you can roll back to.
There Here is a w related thread. It is not about once this happens. A few tips to avoid issue.
- Don't use undo
- Don't exlode spaces or make a Sketchup group or component combining multiple spaces.
- Don't save the SketchUp file unless you need to. Opening th OSM directly is more reliable.
Here is w related thread. It is not about once this happens. A few tips to avoid issue.
- Don't use undo
or componentcombining multiple spaces. - Don't
save thesagr th SketchUp file unless you need to. Opening th OSM directly is more reliable. - Use SaveAs frequently so you have many OSM files you can roll back to.
